Twelve new High-Amplitude Delta Scuti variables from the NSVS and CRTS surveys
by Ivan Adamin, Andrey Prokopovich, Alexandr Ditkovsky, Valery Tsehmeystrenko, Siarhey Hadon in September-October 2013 (#2)
Abstract: As a part of VS-COMPAS data-mining program, here are twelve new pulsating High-Amplitude Delta Scuti variables presented. The research result on these objects is submitted to the VSX catalog for the first time by the VS-COMPAS team members. Photometric data from publicly available surveys (primarily, from the NSVS and CRTS) was used as a source for light curves.
I. Introduction
The δ Scuti variables are pulsating variable stars with periods less than 0.3 days and spectral types A0 to F5. They were known as early as 1900. The large-amplitude ones were classified as RR Lyrae stars, sub-type RRs. Visual amplitudes for Delta Scuti variables are in the range from a few thousandths of a magnitude to about 0.8 mag. As of October, 2013 there are about 360 HADS variables in the VSX database.
The variability of δ Scuti was discovered by W.W. Campbell and W.H. Wright (Lick Observatory). By June 1956, four delta Scuti stars were known (Eggen 1956): delta Scuti, rho Puppis, CC Andromedae, and DQ Cephei. Soon Eggen also discovered a fifth, delta Delphini. And the number of known Delta Scuti stars began to raise rapidly since then.
The Delta Scuti variables form a group which lies in the downward extension of the Cepheid instability strip in the H-R diagram which also includes the classical Cepheids at its bright end and the pulsating white dwarfs. δ Scuti stars can show very complex light variations, since the pulsations may simultaneously include both radial and non-radial modes, i.e. multiperiodic.
In 1955, Harlan J. Smith introduced the term Dwarf Cepheid, which was later used to denote the large-amplitude RRs variables. In the 1970s, Michel Breger showed that the majority of Dwarf Cepheids were not fundamentally different from Delta Scuti stars.
High-amplitude Delta Scuti variables were first classified as AI Velorum stars. Typically, they show non-sinusoidal asymmetrical light curves, similar to those of RRab. Population II HADS stars are called SX Phoenicis and are discovered mainly in the globular clusters. SX Phoenicis variables are generally considered to be a subclass of Delta Scuti variables that contain old stars. SX Phe variables also follow a period-luminosity relation
II. Candidates pre-selection and analysis
Candidates for analysis were selected by a custom piece of software created by Ivan Adamin. The software used the publicly available photometric databases, such as the Northern Sky Variability Survey (Wozniak et al., 2004), The Catalina Real-time Transient Survey (Drake et al., 2012), as a source of photometric measurements.
Then, the whole set of candidates was distributed among the VS-COMPAS Proejct team members for further analysis. During this phase of research there was a custom period search and data analysis software used, created by combined efforts of Andrey Prokopovich and Ivan Adamin.
For high-precision periodogram calculation the Lafler-Kinman (Lafler, Kinman, 1965) statistical algorithm implementation was used. The VizieR web services were broadly used for obtaining data on the objects.
III. The list of discovered objects
Below the results of this research is presented: light curve for each object along with the name of its discoverer and light curve elements (cf. Table 1).
Table 1. - The list of discovered HADS variables.
Object Designation | RA (J2000) | DEC (J2000) | Rise Dur. | Epoch, HJD | Period | Mag. Range |
VSX J024048.2-070617 | 02 40 48.21 | - 07 06 17.3 | 34% | 2451536.735 | 0.0750339 | 13.5 - 13.95 V |
VSX J043039.1+124954 | 04 30 39.12 | +12 49 54.9 | 21% | 2453701.658 | 0.0973764 | 13.85 - 14.4 V |
CSS_J044535.5+012336 | 04 45 35.48 | +01 23 36.6 | 27% | 2455453.994 | 0.0594189 | 14.73 - 15.17 CV |
NSVS 7446012 | 09 14 52.36 | +34 18 34.6 | 40% | 2454094.871 | 0.067751 | 12.90 - 13.28 CV |
NSVS 7467387 | 09 47 05.64 | +32 01 55.0 | 40% | 2454884.684 | 0.1490839 | 13.10 - 13.35 CV |
NSVS 18433413 | 10 01 35.50 | - 24 57 15.7 | 24% | 2454590.947 | 0.0844877 | 13.05 - 13.55 V |
NSVS 13316502 | 14 18 09.96 | - 04 05 22.4 | 26% | 2453524.750 | 0.0853062 | 13.40 - 14.15 V |
NSVS 10553101 | 14 47 29.92 | +11 58 38.9 | 36% | 2454503.994 | 0.0777748 | 13.35 - 13.68 V |
NSVS 10590484 | 15 13 22.01 | +18 15 58.3 | 43% | 2455981.032 | 0.0541911 | 13.40 - 13.70 V |
NSVS 8748519 | 21 19 05.29 | +27 31 47.9 | 60% | 2452836.971 | 0.1148894 | 12.55 - 12.9 V |
NSVS 11718367 | 22 04 02.39 | +14 21 51.2 | 25% | 2452951.523 | 0.0906427 | 13.0 - 13.68 V |
NSVS 17436362 | 23 47 23.28 | -33 37 50.5 | 35% | 2456174.547 | 0.0622458 | 12.76 - 13.2 V |
References:
- Drake, A. J. et al., 2009, Astrophysical Journal, 696, 870
- Pojmanski, G., 1997, Acta Astronomica, 47, 467
- Pojmanski, G., 2002, Acta Astronomica, 52, 397
- Watson, C.; Henden, A. A.; Price, A.,2006-2010, AAVSO International Variable Star Index VSX, VizieR On-line Data Catalog: B/vsx
- Fath, E.A., 1935, "The variability of delta Scuti", PASP 47, 232
- S.V. Antipin, D.M. Kolesnikova, L.A. Sat, K.V. Sokolovsky, S.A. Korotkiy, 2007, PZP, 27, No. 8
- Leung, K.-C., Wehlau, W. ; ApJ, 149, 39
- Rodriguez, E., Communications in Asteroseismology, vol. 145, p. 42-47
- Percy, J. R., 2007, "Understanding variable stars", Cambridge University Press
- Samus, N. N.; Durlevich, O. V.; Kazarovets, E. V.; Kireeva, N. N.; Pastukhova, E. N.; Zharova, A. V. et al., 2007-2013, General Catalogue of Variable Stars, VizieR On-line Data Catalog, B/gcvs
- Sterken, C.; Jaschek, C., 1996, "Light Curves of Variable Stars, A Pictorial Atlas", Cambridge University Press
- Lafler, J.; Kinman, T. D., 1965, Astrophysical Journal Supplement, 11, 216
- Hoffmeister, C., 1949, Erganz. Astron. Nachr., 12, Nr. 1
- Wozniak, P. R. et al., 2004, The Astronomical Journal, 127, 2436
- Laney, C.D. et al., 2003, "HADS, multiple periods, period changes, and the PL relation", in Interplay of Periodic, Cyclic and Stochastic Variability in Selected Areas of the H-R Diagram, edited by C. Sterken, ASP Conf. Proc 292, 203
Free Bulletin on Variable Stars
Variable Stars Observer Bulletin is all about variable stars science. It's made by amateurs and for amateurs. Here simplified contemporary data about different aspects of variable stars research is published. The bulletin is scheduled for six issues per year.
Want to contribute an article? Feel free to contact us at:
http://www.vs-compas.belastro.net/bulletin-contribute
or please simply drop an email to [ivan dot adamin at gmail dot com]
March-April 2014
Free Online
Read Online as e-Magazine
In this issue:
BL Bootis stars - anomalous Cepheids by Ivan Adamin
A revision of NSV 13538 = NSVS 17231162 by Alexandr Ditkovsky
NSVS 11075037 = Dauban V53:
updated elements of a Mira variable in Hercules by Siarhey Hadon
by Siarhey Hadon, Ivan Adamin
by Ivan Adamin
SS Lacertae: The non-eclipsing eclipsing binary by Ivan Adamin
>>View Full Contents
